Driveline noise when running for a while
Old May 24, 2020 | 08:27 PM
Jag4's Avatar
Default Driveline noise when running for a while
Hello forum,
I'm trying to figure out what the cause is for the driveline noise when the car's been running for a while. It sounds like disks spinning up against each other - I've heard other cars in the past with the same sound before. It's not the wine I hear about - that's not it. Its always been like that and it's annoying. Don't really hear anything when its cool or just taking short trips, but after a long drive you can hear it more. It sounds like it's coming from up front, around the center bearing or further up around the back of the engine. When I left off the gas I can still hear it but it fades away once I get down around 15-20 mph. I've tried geasing the bearing but doesn't do much.
The car shifts fine and I just changed the ATF oil. I've read a bunch of threads that talk about replacing the driveline but seems this is always due to the bearing needing replacement and I believe if greasing it doesn't help then it is not the bearing. Or am I wrong about that?
Thank you forum members!
Old May 29, 2020 | 08:08 AM
TonyJ1977's Avatar
Originally Posted by Jag4
Hello forum,
how did you go about greasing the bearing ?
Old May 29, 2020 | 04:13 PM
Jag4's Avatar
Gease gun and a needle. There is a small hole you can push grease straight into the bearings.
Old Jun 3, 2020 | 11:49 AM
JagcatX's Avatar
Hello forum,
Off topic but just wondering what ATF fluid you used?
Old Jun 10, 2020 | 10:13 AM
Jag4's Avatar
Redline all around, for everything. Expensive though. Others are also ok but I don't worry with Redline.
Old Jun 11, 2020 | 10:05 PM
dennis black's Avatar
20 Year Member
thats what i use redline
Spikepaga
Jul 19, 2018 12:51 PM
shaguar330
Jan 24, 2018 02:28 AM
Pacobell
Oct 31, 2013 12:32 AM
05xtypeee
Feb 7, 2012 04:51 AM
Daimler68
Jun 18, 2011 09:42 AM
