Drivers door catch
Old Jan 27, 2014 | 05:16 AM
Ants2505's Avatar
Default Drivers door catch
Please can anyone help? I have a problem with my drivers door catch. I have found it difficult to open the drivers door and the car is not recognising that the drivers door is open
Old Jan 27, 2014 | 05:32 AM
Stuart Beattie's Avatar
Hi Ants if you press and hold the lock button on the remote for around 4 or 5 seconds, it should go through the sequence from 1 to 2 stage locking.
Hopefully that will juggle the recognition?
Has anyone messed with the locks before, there is a post here re the door sticking, if I can find it, Ill post it here.
Regards, Stu
Old Jan 27, 2014 | 08:44 AM
Ants2505's Avatar
Thanks I tried that but it made no difference. Is there a switch in the door catch
Old Jan 27, 2014 | 08:51 AM
Do you have another key?
Old Jan 27, 2014 | 09:00 AM
Try this Ants,
https://www.jaguarforums.com/forum/x...key-fob-79673/
Good luck! Stu
Old Jan 27, 2014 | 10:51 AM
emaraszek's Avatar
I had a similar problem where my car thought the door was always open. I just liberally applied WD-40 to the catch, slammed the door shut, and it's been fine ever since. The sensor is built in to the catch on these cars, it's not a separate button like on many other vehicles.
Old Jan 27, 2014 | 11:30 AM
Hi Evan,
Tut Tut, the new world era states that we should use dry silicon powder these days as the WD40 can erode certain rubber and other stuff.
By the way, I posted on your vehicle being taken to the garage, have you read it or are things now sorted?
https://www.jaguarforums.com/forum/x...rt-car-110483/
Regards, Stu
Ants2505's Avatar
Thanks I've tried that looks like I will have to strip the door down and maybe replace the catch
Old Jan 27, 2014 | 11:31 AM
Sorry It wasn't much help!
Stu
Old Jan 27, 2014 | 11:35 AM
Ants2505's Avatar
Thanks for everything
Old Jan 27, 2014 | 11:37 AM
Evan if my time is used trying to help you, I'd appreciate you clicking thanks and not saying it.
Cheers, Stu
Old Jan 27, 2014 | 11:39 AM
Ants2505's Avatar
Sorry I don't know how to do that cheers stu
Old Jan 27, 2014 | 12:02 PM
Aha, no problem Ants,
At the far end of each speech box on the lower right, there are a few icons, the first 1 is for quoting someone in a reply and the 2nd and 3rd are multi quotes and the last one is "Thanks-Thumbs up".
If someone has spent time, cracked a good joke or just been a complete TOFF, then I click thanks, that person will get an indication of gratitude or an agreement of opinion, it's really very handy and goes a long way to creating a like for like way of appeciation and its great for the techies and guys who do a lot more than me!
Hope you're sorted then, thank you, Stu
Old Jan 27, 2014 | 01:33 PM
Ants2505's Avatar
Well I think I'll have to take the door card off and have a look. The outside door handle it's working properly I have to lift it a couple if times to open the door
Old Jan 27, 2014 | 01:43 PM
A bit of a wild guess from me as I'm not familiar with the X-Type door latch ........
The XK8/XKR door latch has a microswitch which triggers the 'door open' message. This microswitch is a regular fail although it can be given a temporary reprieve with a squirt of WD40.
If the X-Type has a similar door latch setup, it could be your micro switch is one the way out.
Old Jan 27, 2014 | 01:48 PM
emaraszek's Avatar
Originally Posted by GGG
A bit of a wild guess from me as I'm not familiar with the X-Type door latch ........ The XK8/XKR door latch has a microswitch which triggers the 'door open' message. This microswitch is a regular fail although it can be given a temporary reprieve with a squirt of WD40. If the X-Type has a similar door latch setup, it could be your micro switch is one the way out. Graham
That's exactly how the X-Type door latch is setup and I can confirm that I fixed mine with WD-40
99xk8guy
Sep 29, 2025 10:51 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
sadepol01
Sep 11, 2015 05:26 AM
