Drivers door lock
Old Jun 22, 2013 | 12:37 PM
MRomanik's Avatar
Veteran: Air Force
Default Drivers door lock
My driver's side door(LHD) will not lock with either the key or remote.All other doors are ok. I've checked the linkage rods & cable. They appear to be working. The motor clicks when activated by the remote.
Is the Latch motor a repairable unit or do I need to replace it?
Old Jun 22, 2013 | 02:28 PM
disguay's Avatar
I have had this problem many times before. Sadly, you are going to have to replace the door actuator with another one. Luckily, the repair is super straight forward if you have the correct security bits to remove the actuator from the door. Here is the part if you are interested: 2002 2008 Jaguar x Type Genuine Front Left Lock Actuator | eBay
Right now, you may be able to get away with putting some lube on all of the joints, but what I have found with these actuators is that once they start acting up like this, it is much less of a headache to just replace it with a working unit.
Old Jun 23, 2013 | 07:50 PM
Jagman68's Avatar
Hi
I had a problem with my passenger rear door RHD I took the lock mech out and undone the screws holding the little motor in place all I needed to do was give the brass contacts a clean after being in there for 11 years they were a bit dirty, I did replace the lock a couple years later but stood me in good as I didn't have money spare to replace it at the time.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
