driver's door problem
Old May 13, 2011 | 12:31 PM
baffourg's Avatar
Question driver's door problem
hello folks, as u may have noticed i love my x-type but i have one outstanding issue, ie the driver's door does not open sometimes when i press the keyfob though i hear the clicking sound. i have checked the FAQ but there is nothing there on this issue. i would be grateful if anyone could offer me any help in solving this. I am in Ghana and we don't have a jaguar dealer in my country. thanks
Old May 24, 2011 | 08:30 PM
Bdouble's Avatar
Ok I have had a similar issue with my driver door and my problem was that the rod that goes from the handle to the actual lock had loosened and fallen down too far. This will require you to pull up on the handle tremendously to open the door and make you crazy. The higher the rod position the less you have to pull on the handle to open the door. So what you have to do is remove the door panel and peel back the plastic seal on the door. Then you will see two rods coming from the door handle going to the lock. The rod that is the culprit is the one going straight down in to the lock. The rod is locked in to a plastic clip that looks complicated but can be easily unlocked by simply pulling it out with a hook tool. Once unlocked remove rod and raise it up so threaded section is closer to the top of the clip. Now lock rod back in to clip and make sure you test the handle before you put everything back together. This may seem tedious but trust me you will have it fixed in no time.
Old May 24, 2011 | 08:53 PM
I'm sure this has been posted into the X type quick FAQ link thread many times before.
There's also a how to for removal of the door card
Check them out....
PMKimpton
Aug 3, 2019 08:22 PM
XJsc-guy
Nov 23, 2015 01:56 PM
bdboyle
Sep 4, 2015 06:16 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
