DSC System Unavailable light after replacing speed sensor
Old Jan 12, 2020 | 09:51 PM
JagWagon's Avatar
Default DSC System Unavailable light after replacing speed sensor
After battling the car with a C1175 code (for the left-rear speed sensor, not being sure if it was the tone ring or sensor), ABS/Check Engine light stayinng on and, DSC not available, I took apart the speed sensor and saw a bit of the sensor knicked off at the bottom.
I replaced the speed sensor, which allowed me to reset the ABS and Check Engine light. The only thing concerning me is, DSC Not Available is still on.
To be fair, I have only driven on the car a few miles, at city speed (25-35mph).
Any idea if the DSC System Unavailable will disappear, maybe driving highway speeds or, does the car need to be driven more for it to reset? or maybe other resolutions for the system to reset?
P.S: I do have the traction on/off button and, pressing that does not do anything.
Thank you.
Old Jan 13, 2020 | 08:29 AM
TonyJ1977's Avatar
Pull the sensor back out and shine a light in the hole and inspect the tone ring. If a bit of the sensor was chipped off then the chances of the tone ring being broken are also high. The tone ring once broken can move on the axle so when looking at the ring thru the hole turn the axle and make sure it’s still inline with the hole.
Old Jan 13, 2020 | 03:56 PM
max224's Avatar
Had the same problem and it threw a C1165 code that turned out to be for a defective yaw sensor which is located under the shift assembly in the center console. Easy replacement if you have an automatic transmission, giant PIA if it's a manual. You can find them on ebay fairly reasonably or new for almost $ 500! Guess which way I went.
Old Jan 16, 2020 | 12:51 AM
JagWagon's Avatar
I will check the sensor and the tone ring to make sure. I also no longer hear a squeaking while the wheels are turning like I did before.
Thank you Max. I no longer have the ABS/CEL on, confirming with my scanner after driving around the block a few times. I don't get any codes, just the DSC System light showing on the dash. You'd think I'd get a code or something for the Yaw Sensor?
I have an automatic transmission.
Old Feb 5, 2020 | 11:13 PM
JagWagon's Avatar
An update,
Sure enough, it did turn out to be the yaw sensor. Found a used on off of ebay and hooked up. DSC light is officially gone!
Thank you to Max!
Old Feb 6, 2020 | 11:18 PM
Dr dome's Avatar
Default Ring rust
Also make sure not to see any shiny spots on the ring. This could also be the issue. Happened on a car I was working on. Had to replace the axle do to heavy rust coming through where the ring connects to the shaft.
androulakis
Apr 4, 2023 12:04 PM
Stephen Clark
Feb 6, 2020 11:21 PM
Jumpin' Jag Flash
Oct 16, 2015 04:25 AM
RapidRabbit
Jul 8, 2012 04:58 PM
Andy
Jan 9, 2009 04:36 PM
