ECU connector
Old Jul 4, 2024 | 07:34 AM
BradsJag's Avatar
Default ECU connector
Just a quick question for a change.
Can someone remiond me what size and type of screwdriver tip is required to remove the main connector on the ECU ? I thought is was 5 star 25
Old Jul 4, 2024 | 10:39 AM
dh53's Avatar
5 star 30, but with the security pin so the bit needs a corresponding hole in the center.
Old Jul 4, 2024 | 11:02 AM
BradsJag's Avatar
I knew it was 5 star and I was close with no: 30. Still couldn't find one in my security bit sets, then, I realised something, I found a flat bladed screwdriver with a notch cut into it. That is what I used before. Anyway, thank you for your reply.
Old Jul 25, 2024 | 04:52 PM
Enormiss's Avatar
Can the whole ecu be removed while the plug is still connected?
I removed the two 10mm bolts but don't know if it pulls up from under hood or down from interior...
Old Jul 25, 2024 | 07:35 PM
Dell Gailey's Avatar
Old Jul 26, 2024 | 03:57 PM
Enormiss's Avatar
Thanks! Was hoping to get it out of the way without resetting any data... bummer
Old Jul 26, 2024 | 05:06 PM
motorcarman's Avatar
It is called a T30 TORX PLUS tamper proof
djmccoy77
Jul 30, 2025 01:29 PM
Cr0wTom
Oct 25, 2023 08:27 AM
Dallyb
Dec 16, 2021 04:00 PM
thekiltedwonder
Aug 16, 2021 03:18 AM
Doug
May 22, 2017 03:56 PM
