Electrical/ engine problem
Old May 4, 2019 | 01:29 PM
Spiro Drago's Avatar
Default Electrical/ engine problem
Hello everyone, I own a Jaguar X-Type 2.0 tdci. Recently i am seeing that the RPM are moving constantly/simultanosly from 800 to 1000. Also when this thing happens the lighting system is also having some problems, getting lightner-brightner by himself. I would like some ideas to know what is happening or what is causing all that. Thanks in advance guys.
Old May 4, 2019 | 01:55 PM
Welcome to the forums Spiro Drago,
I've moved your question from Off Topic to X-Type forum. Members here with the same model will be able to help.
Old May 4, 2019 | 04:51 PM
Thermo's Avatar
Veteran: Navy
Spiro Drago, from the sounds of things, your idle air control valve for the engine is sticking and that is causing the engine to hunt like you are seeing. A good cleaning with say some carb cleaner. If you car doesn't have an IAC valve, then odds are you are looking at fuel pressure regulator that is sticking and the fuel rail pressures are going all over the place, altering the amount of fuel going into the engine.
Old May 4, 2019 | 09:17 PM
Dell Gailey's Avatar
Last post maybe? This usually has an accompanying flashing glow plug light, but not always. EDIT = forgot to post the thread link, so here is the video of what I thought may help. Pretty common problem with diesels.
Cough
Jan 4, 2011 04:45 PM
frederikv12beauty
Jul 22, 2010 08:49 AM
gburns
Aug 8, 2009 10:10 AM
eurodmguy
Mar 11, 2009 09:23 PM
