At the end of my rope with this cat
Old Dec 14, 2023 | 02:59 PM
NYCJAG2006's Avatar
Default At the end of my rope with this cat
Just paid for a new brake booster and for installation. 10 minutes later. Check engine light back on. Same damn codes. This time the P0171 says pending. And P0174 is current. What a waste of money !!!! Seems like nobody can fix this damn vacuum leak. What do I do now ????
Old Dec 14, 2023 | 07:09 PM
Peter_of_Australia's Avatar
Apart from checking for vac leaks, I assume you...:
...P0171: checked and cleaned the MAF sensor? Checked (replaced?) bank 1 upstream O2 sensor?
...P0174: Checked (replaced?) bank 2 upstream O2 sensor?
And I found this - it's S-Type, but I'd assume there is an equivalent X-Type situation...:
Old Dec 15, 2023 | 08:04 AM
Dell Gailey's Avatar
Old Dec 19, 2023 | 04:08 PM
NYCJAG2006's Avatar
Ok. So. New brake booster. Booster vaccum line. Imt o rings. And still need to do the pcv valve and hose. Too cold today. I had the same issue last year. P0174 only. It was finally resolved (I thought). When my mechanic changed out the bank 2 upstream sensor. The one under the air box. I bought an oem Jaguar sensor. For the ridiculous price of $350 bux. That got rid of the check engine light and I was able to get and pass my inspection. 5 months later I got the P0174 code again. Then in the last few months getting P0174. And occasionally P0171. Is it possible that the new sensor crapped out after 5 months ? Then bank 1 sensor also craps out ?? How long are these sensors supposed to last. Can’t get the cat inspected. And my inspection has been expired since October. Don’t know what else to do. I’m reluctantly thinking of taking my car to the dealer !!! Any help
is greatly appreciated. Happy Holidays
NYCJAG2006
Nov 23, 2023 12:24 PM
wordman
Feb 18, 2020 09:38 PM
Jagmag
Mar 19, 2012 06:13 AM
ness
Nov 22, 2008 11:26 AM
kandA
Mar 11, 2008 06:43 PM
