engine codes!
Old Jan 2, 2019 | 04:59 PM
Harry Peter Rose's Avatar
Default engine codes!
HELP! ....losing hair / losing sleep /.......need to resolve issue SAP!
Continuing problem from engine warning light coming on and retrieved codes /well established service shop with good reputation with X Series etc. {but I am getting nervous!)
2002 2.5 AUTO /AWD /Petrol 65,000 miles
3/8/2018/ CODES P0171 & P0174....Cruise control unavailable message...
Replaced upper intake manifold upper air control valve seal.......codes cleared
RAN WELL UNTIL 12/6/2018/ ENGINE WARNING LIGHT /CODE P0I71
Smoke test for leaks ....Replaced intake manifold tuning actuator seals and booster hose assembly
12/19/18 ...ENGINE WARNING LIGHT /CODE P0I71 & P0174
Suspected cause...lean condition one or more fuel injectors on each bank
Performed Engine Decarbonizing and Fuel Injection Cleaning SERVICE
Motorvac throttle body plenum and intake cleaning / Motorvac internal combustion chamber cleaning
Codes removed and drove well for next couple of days ....Engine Warning light back on with occasional Amber Light for a few minutes
Anyone have had similar problem and can suggest anything? / very appreciated.....Do I change mechanic? or just what the hell are they missing?........
Old Jan 3, 2019 | 03:26 PM
JagV8's Avatar
Change shops or DIY.
For DIY get a cheap OBD tool and use live data to see fuel trims - read forum messages about how & those codes.
Stop swapping parts at silly cost and find out what is actually wrong.
Old Jan 3, 2019 | 06:32 PM
THANKS JAGV8...…....appreciated
OBD TOOL PROVIDED CODES P0171 & P0174.... Mechanic hopefully has been looking "live data to see fuel trims"
what should he be doing~
update last two days engine has stayed off!>>>>>>>>>>>?
Old Jan 3, 2019 | 07:39 PM
Dell Gailey's Avatar
P0171 & P0174 are nearly always a vacuum leak. Just do a search here and read the conditions and results. There are too many threads to repost.
Old Jan 4, 2019 | 09:30 AM
astromorg's Avatar
+1 above
A common cause of those codes has been the 1 in dia crankcase breather hose from the cambox nearest the radiator to the inlet manifold. It wears and splits on its underside out of sight
Old Jan 4, 2019 | 11:55 AM
Alfadude's Avatar
Also check the brake booster check valve and check the accordian hose between the MAF sensor and the throttle body to make sure it isn't split or loose.
Old Jan 5, 2019 | 01:23 PM
https://docplayer.net/23575791-Dtc-p...OVdONUZHdlF0eA..
jaguar0206
Dec 8, 2019 07:43 PM
SynySTR
Oct 17, 2014 09:33 AM
bassman64
Apr 20, 2014 04:25 PM
XTypeJagMan
Feb 28, 2014 08:38 AM
michaelnv
Feb 4, 2007 05:14 PM
