Engine codes...???
Old Feb 29, 2008 | 04:31 PM
Supralative's Avatar
Default Engine codes...???
Once you fix the supposed problem, does the ECU take awhile to cycle itself and clear the codes, or do you need to go have them cleared?
I replaced the two leaky intake valve seals on the manifold near the passenger side today.
Old Feb 29, 2008 | 04:35 PM
Cadillac's Avatar
Default RE: Engine codes...???
After a few period of successful cycles if the PCM detects no fault they should be gone away .This is how GM,MB PCMs work and I think so is X Type's
Old Feb 29, 2008 | 06:58 PM
jag_genius's Avatar
it will eventually erase the code..i think it does take several drive cylces to actually turn off the light(may take a while) has to be full warm up from cold .
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
