Engine Fault/Transmission Fault
Old Aug 26, 2016 | 09:42 AM
xtypejag502's Avatar
Default Engine Fault/Transmission Fault
My 2005 X-Type stalled at a light a couple weeks ago. The oil light flashed like crazy and then I got engine default and transmission fault readings on the dash. The car had a terrible knocking noise. I was able to put it in drive and slowly make my way to the side of the road to wait for a tow. It's been sitting for almost 3 weeks now. Yesterday I needed to move it. When I started it I heard the loud knock and then it went away. No oil light or transmission fault/engine fault readings. I can still hear a slight knock. Coolant and oil levels are all good. Any suggestions?
Old Aug 27, 2016 | 08:46 AM
swingwing's Avatar
How many miles on car? I'd say the knocking sound is from the engine, especially if you hear it when not moving. I recommend doing an oil analysis. Blackstone is one vendor you'll see commonly referenced; I use kits available from AMSOIL. That will help guide you. Good luck.
Old Aug 27, 2016 | 09:18 AM
The car has 119,920 miles on it. I'll look into it. Thanks!
aholbro1
Feb 14, 2021 01:51 PM
NW1996
Apr 3, 2016 06:56 AM
Dean Kitching
Mar 30, 2016 02:53 PM
Joshua Soon
Mar 30, 2016 11:57 AM
Diavolo
Mar 25, 2016 01:27 AM
