Engine light on and DTC’s
Old Nov 3, 2024 | 11:51 AM
Dawson994's Avatar
Default Engine light on and DTC’s
Hi everybody! This morning, starting the car at work, the engine light has turned on but without malfunctions.
Arrived at home i did the test and i got those errors:
DTCE510
DTC9202
DTCA627
DTCA879
can you tell me what are they?
Old Nov 3, 2024 | 11:55 AM
NBCat's Avatar
DTCs set by the PCM/ECM for Powertrain faults begin with the letter 'P' followed usually by a '0'. For instance, P0171 or P0420.
It's not uncommon for there to be misfires that do not set a DTC or turn on the MIL, such as faulty coil units.
Old Nov 3, 2024 | 03:13 PM
h2o2steam's Avatar
Looks like your code reader is delivering non-jag specific codes.
E510 might be explained by this thread.
https://www.jaguarforums.com/forum/x...-codes-139972/
Your remaining codes (DTC 9202, DTC A627 & DTC A879) again are not directly listed as Jaguar codes,but might be pointing to a bad fuel sender and or fuel tranfser pump or wiring issue to either.
Old Nov 3, 2024 | 05:10 PM
Thermo's Avatar
Veteran: Navy
Dawson, the codes you list are those that came from the instrument cluster. Those codes may have been set today, they may have been set 5 years ago. You don't know. I would recommend going to a local auto parts store and having them read the codes for you. Then post those code(s) here. Those are going to be a lot more useful. Yes, what you listed can be converted, but there is no saying whether they apply to your current problem or not and they could very easily send us on a wild goose chase, causing you to have to buy and replace things that don't need to be.
Bgrizzle
Apr 28, 2022 06:16 PM
SpartanBadger
Nov 16, 2021 08:37 AM
Simon99
20
Aug 25, 2019 05:51 AM
rjcl004
Jun 2, 2017 12:30 PM
harounq21
Aug 8, 2008 06:42 PM
