English or metric?
Old Oct 19, 2010 | 12:12 PM
JaguarKnight's Avatar
Default English or metric?
My X-Type is missing a lot of the bolts that attach chassis and body parts, and others seem to be the wrong bolts. I assumed they would be metric, so I bought some 6mm-1.0 bolts and tried them. Those did not fit, so I thought that maybe, just maybe, they might still use English bolts in England. So I bought some 1/4-20 bolts. Those don't fit either. The heads of most of the bolts that seem to be the correct ones have hex heads that fit a 10mm wrench, but I have not tried to see if a 3/8 or 5/16 wrench would fit. So, what size are these bolts? 1/4-28? 6mm-0.75? Or some special Jaguar proprietary size?
Old Oct 19, 2010 | 01:20 PM
sidewalkman's Avatar
I would have assumed they were metric, one of the geniuoses will doubtless chime in but there is a thing call british standard as well.
Old Oct 19, 2010 | 05:07 PM
Thermo's Avatar
Veteran: Navy
All the bolts on our cars are metric.
Please keep in mind that there is also 2 different thread sizes too. So, not only do you need the correct diameter bolt, but you need to also get the correct pitch of bolt. This is where getting a large assortment of bolts and playing with what works where will be your best bet.
Old Oct 19, 2010 | 05:19 PM
Tony_H's Avatar
I think I've found both English and metric sizes. In addition, Ford uses even metric (8, 14, 18mm) versus the odd metric(7, 9, 13, 15, 17mm) that most European cars use. It's a mystery.
Old Oct 30, 2010 | 09:02 AM
gragner66's Avatar
my x type on what work ive done so far is both metric and standard. I did some brake work all was metric but the large nut holding hub on was 1 1/4
aholbro1
Dec 29, 2024 06:46 PM
wonderwire
Oct 4, 2015 05:41 PM
Safari
US Central
Sep 21, 2015 09:34 AM
Nigels420G
Canada
Sep 16, 2015 10:27 AM
