Entertainment System Dead
Old Feb 3, 2015 | 12:56 PM
kenpem's Avatar
Exclamation Entertainment System Dead
Hi folks
'59-reg X-Type with the Denso sat-nav system.
I found an excellent photo-tutorial on here a week ago, about how to clean and tune the sat-nav DVD unit. I can't find that thread now! If anyone could point me at it, I'd appreciate it.
Followed it carefully, unfortunately unsuccessfully ("The disk installed is not a map dvd"), so maybe a worn/weak laser wasn't the problem after all. Or maybe the problem I'm left with is just part of the bigger one...
NO ENTERTAINMENT AT ALL. Radio tuner screen comes up, but no sound. CD appears to play, but no sound. CD Changer... system doesn't seem to think there is one!
This "feels" like I've knocked out a fiber-optic connector somewhere... does that sound likely? Anyone come across this before? That cage in the boot is a nightmare to work around, so I'd appreciate some pointers before I climb into it again.
One thing... when I removed the fiber cable from the back of the DVD unit, a little spring fell out of it. I couldn't see where it came from.
Old Feb 3, 2015 | 01:03 PM
rapala's Avatar
There is a white plug for the fibre-optic system that fits into the bottom of the cabin fuse box. This plug has been known to come loose in the past.
Old Feb 3, 2015 | 01:09 PM
kenpem's Avatar
Thanks, rapala. "the cabin fuse box" - as in, up in the front of the car? How likely is it that came loose while I was working in the boot?
On the other hand, stranger things have happened...
kenpem's Avatar
Oh, and I found the original thread... Search Results - JaguarForum.com - The World's # 1 Jaguar Car Forum
Old Feb 3, 2015 | 01:12 PM
kenpem's Avatar
argh stoopid pasting error! I can't remove or edit posts, please ignore above! This is the correct link: Jaguar Denso SatNav DVD Drive Cleaning/Tune Up
Old Feb 3, 2015 | 01:19 PM
rapala's Avatar
The fuse box I'm on about is accessed by removing the small panel in the back of the glovebox or better still by removing the glove box. I wouldn't imagine anything you did at the back of the car would affect the plug at the front though.
Old Feb 3, 2015 | 01:25 PM
rapala's Avatar
Article - D2B Linking Fibre Optic Cables.pdf -- June 19, 2011 8:45 pm -- 414k
Hopefully the above link will work for you, have a read through it as it seems that the small spring you mention earlier in the thread is part of the fibre-optic plug.
Old Feb 5, 2015 | 11:07 AM
CyberWizard's Avatar
I don't know if it helps but my cd changer died on me and I had all the same symptoms as yours. As it was completely dead, the optical daisy chain was broken so the audio amp could not work and hence no sound. replacing the changer with a new one cured the problem so I would say you are definitely having a optic link problem
Old Feb 7, 2015 | 06:59 AM
davezx's Avatar
After having the same problem as yourself only a few weeks ago and having the exact same dvd message displayed I can pretty much assure you that it's not a optic link problem but quite simply a dvd player problem.
Replace the dvd rom unit and it will instantly all come back on for ya.
2001 White XJ8
Feb 25, 2021 05:02 PM
Safari
US Central
Sep 21, 2015 09:34 AM
Jagfastic
Sep 14, 2015 07:41 PM
adam699
Sep 12, 2015 05:32 PM
