Estate Liftgate window Strut replacement
Old Feb 4, 2020 | 02:13 PM
Tijoe's Avatar
Default Estate Liftgate window Strut replacement
My Estate rear window air struts are bad. This winter, in the cold weather, the tailgate no longer stays up on its own. I've been using a stick to hold the rear liftgate up. A few days ago, in heavy winds, the lift gate blew up further, the stick fell out and it fell very quickly onto my head. Ouch! Gave me a huge knot on the top of my head. (Plus a lot of jumping around, numerous profanities, along with birds and stars flying around my peripheral vision.
I've searched the forum but have not been able to find a description of the best way to lower the rear of the headliner in order to replace the 2 window struts. (Dell Gailey to the rescue?)
I did find this searching the web, they they don't explain how to replace the window struts: https://www.jaguarforum.com/showthread.php?t=55320
Has anyone recently purchased a set of 4 of these struts? If yes, confirmation of the current P/Ns would be good. I'll purchase 8 of them to replace in both my Estates when I find the best price.
Thanks.
Old Feb 4, 2020 | 02:17 PM
Tijoe's Avatar
Forgot to ask if anyone researched higher eject force Struts for the Estate so the the tailgate might open on its own. (Like posted in threads about the regular X-type trunk struts.)
  • Sachs SG266004-W
  • OEM Numbers: 4X43N406A10AC
  • Length 1 [mm]: 538 mm
  • Eject Force [N]: 455 N
  • Extended Length A [in]: 21.16
  • Stroke C [in]: 7.64
  • Compressed Length B [in]: 13.52
  • Force (Lbs): 102
  • Force Newtons: 455
  • Shaft Connection: Ball Socket U Band (Nylon)=10mm=3/8"=.39"
  • Body Connection: Ball Socket U Band (Nylon)=10mm=3/8"=.39"
  • Rod Diameter (MM): 8
  • Cylinder Diameter (MM): 18
  • SKU: SG266004-W
  • A Interchanges: 0611RO,2575YC,4X43N406A10AC,4X43-N406A10-AC,SG266004
Old Feb 4, 2020 | 02:45 PM
Tijoe's Avatar
Turns out the information I posted above is only for the tailgate struts. The window struts are different and it took some time to find a P/N
JAGUAR PART NUMBER: C2S23550, C2S37601
https://parts.jaguarpalmbeach.com/a/...E/4735650.html
Plus this link showed on on internet search after I found the P/Ns and searched under the P/N.
https://www.jaguarforums.com/forum/x...s-help-215442/
Old Feb 4, 2020 | 03:45 PM
Alfadude's Avatar
Here is a link that explains where to find the headliner information. https://www.jaguarforums.com/forum/x...pports-131888/
Dell Gallery? Wasn't that an old show hosted by Rod Serling?
Old Feb 4, 2020 | 07:54 PM
Dell Gailey's Avatar
Neeno, neeno, neeno, neeno.....(twilight zone theme music), lmao
Johnken
Aug 22, 2024 12:00 PM
MisplacedPriorities
Sep 16, 2019 08:36 PM
ncanales33
Dec 27, 2018 05:08 PM
hlgeorge
Feb 19, 2017 09:08 PM
XK8+XJ8L
Aug 19, 2011 12:59 PM
