Exhaust fumes in ventilation system
Old Sep 18, 2010 | 01:43 PM
Thermo's Avatar
Veteran: Navy
jafar, based on what you are describing, you have a problem with the exhaust header more than likely. I would have thought the dealership would have found that. But, maybe not.
What you can try is taking a piece of rubber/tygon tubing and holding one end up to your ear and running the other end along the exhaust system (all the way from where it exits the engine, past the turbo, on back to the firewall). Try to make it as far around the pipe as possible at any joint and at key parts like the exhaust manifold and turbo. If you start hearing a whistling sound or a chugging sound that is louder than in other places, you have found your leak. Then it is a matter of figuring out what the part is and how to fix that part. Something like a turbo or exhaust manifold will require replacing the part. If a joint is leaking, may just have come loose and a simple tightening of the joint will fix the issue.
Wish you luck.
dsnyder586
Dec 29, 2024 07:39 PM
Daim
Nov 28, 2016 09:28 AM
Aus V8S
Nov 13, 2015 11:01 AM
XJ8JR
Sep 11, 2015 12:31 AM
Quebecjag
Sep 10, 2015 06:06 AM
