Expansion tank upper hose - is this normal ?
Old Dec 29, 2019 | 07:29 AM
Davidvdm's Avatar
Default Expansion tank upper hose - is this normal ?
This hose is soft and flexible at the end attached to the engine, but firm along most of the hose to the end attached to the expansion tank. Is this normal, or is the hose defective where it is soft ?
Old Dec 29, 2019 | 09:29 AM
Thermo's Avatar
Veteran: Navy
David, if it is soft only in a limited location, that is the hose starting to break down. Now is the time to replace it before it fails and leaves you stranded. Granted, my memory is saying that the hose should be soft, not hard. Either way, the hose has an issue. Been too many years since I had my X-Type and things are starting to not be as clear as they once used to be.
Old Dec 30, 2019 | 06:05 AM
Davidvdm's Avatar
Many thanks, Thermo. I have ordered a new hose and am curious to see how it compares with the old one.
grantorino62
Aug 26, 2016 02:45 PM
n8ertot
Oct 26, 2015 01:18 PM
chrisc923
May 20, 2014 02:02 AM
Windycityx
Nov 7, 2013 07:43 AM
Lannyl81
Feb 10, 2013 08:59 AM
