Factory HIDS
Old Apr 3, 2009 | 03:41 PM
and1carter's Avatar
Default Factory HIDS
hi, i was wondering is it possible to change out your halogen headlamp with a xenon headlamp?
Old Apr 3, 2009 | 04:41 PM
jfenley's Avatar
yes you can, simply purchase the Xenon HID head light assembly, remove the front bumper, remove the halogen head light assembly and install your new Xenon assemblies. The factory wiring harness is identical for both. It's plug and play. (new Xenon HID assemblies cost $900+ each)
If you go to e-bay, be sure to check the "adjustment screw". Normally these are already broken and the seller does not realize that they are selling a damaged part.
If you were thinking aftermarket kit. There are several to choose from.
Old Apr 3, 2009 | 09:07 PM
Brutal's Avatar
and if you buy broken ones you can take them apart and repair. I do these on the side for extra money. starting @$125 a pair and up. Thats you sending yours to me
Old Apr 4, 2009 | 12:09 PM
and1carter's Avatar
the autobody shop put xenon headlamps in and when i got the car back they were not working. they were telling me that the wires were ****ed up or some ****. now that i got the xenon headlamps will the headlights auto adjust
Old Apr 4, 2009 | 07:25 PM
jfenley's Avatar
Mine is an 02, it does not have the auto adjust lamps. You have to manually set them. I don't know too much about all the "options" it might have had from the factory. I do know tht the S-type has auto adjust if optioned with it. As far as the x-type auto adjust????
Old Apr 5, 2009 | 01:38 AM
Master Deep's Avatar
I thought ALL HID's Auto adjust from the factory. It's required by law if the lights are to be legal.
Hence y all the aftermarket products tend to say "For off-road use only"
Old Apr 6, 2009 | 12:29 PM
timfountain's Avatar
Ok, the upthread poster who said they were plug and play is wrong. There is an extra ground wire you need to run on the HID's over the halogens. Also you will not get auto adjust without the height sensors on the front and rear wheels and the auto levelling control box. This is for US spec cars, not sure about other countries WRT to levelling.
When I modded my X-type, I removed the auto levelling mechanism from the HID's and run the extra ground wire to the chassis. I never had issues with blinding other drivers. If you left the stepper motors for auto levelling in the HID's when you put them in your car, the lights will be pointing down with no chance for adjusting them. Drop me a PM if you want the PDF with the schematics so you can see the defferences.
- Tim
Old Apr 6, 2009 | 01:05 PM
turky's Avatar
Default HIDs
Thanks for this info as i think i am in deep s*** with my headlights as well
some one has fitted these HIDs to my car X type I was told that they need adjusting, so I took it to a garage and sked them to line them up for me only to be told the adjusters must be broken, so am I looking for a new pair of headlights or can they be fixed?????
Old Apr 6, 2009 | 01:55 PM
H20boy's Avatar
If you need them fixed, see post #3 above turky.
Old Apr 6, 2009 | 10:20 PM
and1carter's Avatar
well i bought my car used and it came with halogen headlamps and then recently i got in an accident and when they checked the VIN for the headlamp they said it came from the factory with xenon headlamps so do you think that it will have the auto leveling feature?
Old Apr 7, 2009 | 06:47 AM
The Chris X's Avatar
How would you know if you "never had issues blinding other drivers" ?
Old Apr 8, 2009 | 10:31 AM
turky's Avatar
Well Chris my off side was way out when you can see the driver of the car coming in the opposite direction quite clearly in the dark on diped beam then you know you have problems, well I had mine checked out and sure enough the adjusters were broken.
Larry-Cleveland
Feb 9, 2019 03:17 PM
damienedwards
Nov 22, 2015 10:51 AM
Johncy2000
Oct 2, 2015 01:05 AM
42Ajd
Sep 26, 2015 07:04 PM
