fans
Old May 11, 2009 | 03:49 PM
perezrp101's Avatar
Default fans
what fuse or relay controls the fans or if their aint one i guess my fans are f&& up
Old May 11, 2009 | 04:09 PM
racerx82's Avatar
When you says your fans are forked up, what does that mean....not working? Fans staing on all the time? engine overheating?
ok..ok..i give up...
Old May 11, 2009 | 04:12 PM
perezrp101's Avatar
Default off
they dont turn on the stay off
Old May 11, 2009 | 04:17 PM
racerx82's Avatar
If i remember correctly, all the fan fuses are in the engine compartment fuse box. when you lift the cover, the fuses are marked. Find the relays that say fan1 fan2
I'm gonna guess it's the fan controller. They have a nasty habit of going bad. What year is your jag?
Old May 11, 2009 | 04:38 PM
perezrp101's Avatar
its a 2002 and i cant find the relays that say fan1 and fan 2
Old May 11, 2009 | 06:40 PM
racerx82's Avatar
hmmm, let me check the manual....
Old May 11, 2009 | 06:49 PM
racerx82's Avatar
OK,
Your model doesn't have a relay or fuse. Your fans are controlled by the fan control module.
You'll find it under your air cleaner intake slightly to the right of it. silver aluminum box with ribs......
it's probably fried....but im sure you can test it.....
new from the dealer is about 150.
Old May 12, 2009 | 08:48 AM
perezrp101's Avatar
what do you mean i could test it? i think its more than 150 for that part??
Oh yea i called the dealer and they told me i need the whole fan and the control because its all one part you think thats right thanks for the fast reply
Old May 12, 2009 | 05:05 PM
racerx82's Avatar
Yes, for the 2002 model year, 2004-2006 you can buy them separate....
Old Jul 16, 2009 | 12:47 AM
patrick12's Avatar
i have this same problem with my 2002, you say here is not possible only to change the module? (i have found only the module on ebay)
i was allways thinking 2002-2007 have the same cooling fan modules.
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
LnrB
Oct 13, 2015 12:45 AM
workworkwork
Oct 1, 2015 01:44 AM
Darrenmb
Sep 27, 2015 08:43 AM
