Fault code 58-20?
Old Mar 25, 2008 | 08:18 PM
ItalianXtype's Avatar
Default Fault code 58-20?
I got my car back from jagday and when i pull up the diagnostics on the Nav screen there is a fault code 58-20. The fault code time and date shows that it happened after jag closed last night. Does anyone know what that code is?
Thanks in advance
Old Mar 25, 2008 | 08:34 PM
FactoryJaguarTech's Avatar
Default RE: Fault code 58-20?
Is that definitley the code?
LCD DISPLAY FAULT CODES
CODE DESCRIPTION
50 Communication failure between control module and display unit at startup.
51 Communication failure between control module and display unit during operation.
52 Communication failure between control module and display unit during operation.
61 Control module ROM failure. Checksum error during start up.
62 Control module RAM failure. Read/write error during start up.
71 Backlight lamp failure during operation.
74 Backlight lamp overcurrent.
75 Video power supply failure.
76 Display unit over temperature.
79 Teletext failure (when fitted)
91 Soft switch malfunction.
92 Soft switch malfunction.
C1 Communication failure between synchronised signals.
Old Mar 25, 2008 | 08:41 PM
I just checked it and it says (01) 58-20 under diagnostic error codes
Old Mar 25, 2008 | 08:51 PM
May not be anything to worry about if all is working well.
Old Mar 25, 2008 | 09:00 PM
Yeah everything is fine (I think), So I guess your right. I was just curious about what the code was because there is one in there from sometime in 2006 too and I'm thinking it has something to do with the vehicle inertia switch.
Old Mar 26, 2008 | 06:36 PM
jag_genius's Avatar
nav will only give you telematics codes.. no powertrain codes.
philwarner
25
Jun 26, 2021 05:43 AM
cissdm
May 3, 2016 06:02 AM
Dixie61
Sep 19, 2015 06:29 AM
tonyforman
Sep 10, 2015 07:23 PM
skadmiri1
Sep 9, 2015 11:27 AM
