FAULT CODE P1647
Old Jan 20, 2009 | 05:38 PM
morales8416's Avatar
Default FAULT CODE P1647
Hows it been guys. Been a while for i am in the military i come and go at all times. Well i get in my little kitty today and i get a check engine light. Checked out the fault code and says P1647 manufacture control computer output circut. Whatever that means. Looked around and it has something to do with the O2 sensors. I had them all changed less than 6 months ago. With the fast knowledge out there i know someone can help. I am in Miami and the the nearest place is the Collection which is little pricey. If i can do it myself great!
let me know
thanks
Old Jan 20, 2009 | 05:57 PM
suv7734's Avatar
Default RE: FAULT CODE P1647
I've foundhttp://enginelighthelp.informe.com/j...ank-2-dt5.html site helpful for a couple of things and this link is directly related to your code.
Old Jan 20, 2009 | 06:08 PM
roger i saw that but nothing how to fix it
Old Jan 20, 2009 | 06:12 PM
ok excuse me i take it back i thought i been to that site before. so basically it might be a loose connection to the oxegen sensor. so next thing is which bank is which banck one or two how we number our oxegen sensors? which is which
Old Jan 20, 2009 | 07:59 PM
Real_Tech's Avatar
Bank 2 is the bank closest to the radiator. The first thing I would check is the wiring to the sensors for that bank. The harness connectors for both the upstream and downstream o2 sensors are connected to a sheet metal bracket in front of and below the battery. The connectors should be attached to the bracket and the wiring should be routed through a clip arrangement attached to the cooling fan shroud. If the harness has become displaced from the clips on the shroud or the connectors are displaced from the metal bracket the wiring can be fouled by the fan. If that checks o.k. check the fuses for the o2 sensor heaters. I don't have an electrical guide in front of me but I believe the fuses ar in the underhood fuse box, just check them all.
Old Jan 30, 2009 | 10:08 AM
ok i checked everything in above post. and nothing still throwing the same code. Whats the most logical next step without sending the car to the dealer. Change the oxegen sensor completly? please advise
thanks
Old Oct 12, 2010 | 08:11 PM
4470nautilus's Avatar
I just had the O2 sensor replace it was code 1647 which shows to be bank 2 but the code is still there.. What else could be going on
Old Nov 17, 2011 | 03:04 AM
ThomasX's Avatar
Hi
How was this resolved in the end?
philwarner
25
Jun 26, 2021 05:43 AM
cissdm
May 3, 2016 06:02 AM
Dixie61
Sep 19, 2015 06:29 AM
tonyforman
Sep 10, 2015 07:23 PM
skadmiri1
Sep 9, 2015 11:27 AM
