fault codes
Old Apr 14, 2015 | 09:57 AM
fourbyfourbyfar's Avatar
Default fault codes
hi all can anybody help i have abs fault code rear left i think c1174 also p1796 has come up as well now could the abs fault cause the later any help would be great
Old Apr 14, 2015 | 11:04 AM
santer's Avatar
Just in case it helps anyone see if the two are linked
ABS light illuminated
" C1174 Park Brake Switch # 2 Applied Circuit Failure "
Jaguar Check Engine Light DTC Trouble Codes
" P1796 Kick Down Switch Circuit Malfunction "
Old Apr 15, 2015 | 01:19 AM
checked codes again and i have C1175 rear left speed sensor open or short circuit and P1796 which is can circuit malfuction also P1000 which i think is self test interupted not anything to worry about so was wondering if the speed sensor was causing the 1796
philwarner
25
Jun 26, 2021 05:43 AM
cissdm
May 3, 2016 06:02 AM
Dixie61
Sep 19, 2015 06:29 AM
tonyforman
Sep 10, 2015 07:23 PM
skadmiri1
Sep 9, 2015 11:27 AM
