Final anser... what TC fluid plz?
Old May 22, 2009 | 05:25 PM
matl's Avatar
Default Final answer... what TC fluid plz?
Hi i've been reading endless pages on this and i see Royal Purple, Syn Go and GL-5 synthetic as recommendations. Will any work or have we found through trial/error one to be best? Do you also recommend adding an additive? if so which type? thanks for the help.
Old May 22, 2009 | 07:57 PM
racerx82's Avatar
Save your money...Dextron 6 works great and is a few dollars cheaper
Old May 22, 2009 | 09:47 PM
ant1.0's Avatar
The Dextron 6 can be used on the rear diff right?
Old May 22, 2009 | 09:57 PM
racerx82's Avatar
I'm not too sure about the rear.....
Old May 23, 2009 | 05:47 AM
Thermo's Avatar
Veteran: Navy
The rear differential and the transfer case both use the same fluid (75W-140 full synthetic based fluid). That is where the GL-5 comes in to play as GL-5 is a standard for that type of fluid, no so much a brand name. People have used Redline, Royal Purple, etc and have not had any issues that could be related to the fluid. I personally use Mobil 1. 6 of one, half a dozen of another. As long as it has the GL-5 rating, you will be just fine.
Now, as for the Dexron VI fluid, I personally would not recommend putting that in the transfer case. Dexron VI fluid is a transmission fluid, not a gear fluid. The physical properties of the two are completely different. I have a feeling that if you put the Dexron VI fluid into the transfer case, you will have serious issues in a short period of time. Now, if you plan on putting it into the transmission only, then you should be fine. But, again, I would double check the specs on the fluid and see how that compares to what is recommended. As long as it has the same ratings maintained (or exceeded), you will be just fine.
Old May 23, 2009 | 12:51 PM
matl's Avatar
Good to hear, thanks for the explanation
aholbro1
Dec 29, 2024 06:46 PM
TreVoRTasmin
Sep 18, 2015 06:57 PM
TreVoRTasmin
Sep 16, 2015 08:14 PM
mrplow58
Sep 15, 2015 09:58 PM
Mamuka Darakhvelidze
Sep 13, 2015 09:35 AM
