Fitting Rear Lower Control Arm
Old May 29, 2022 | 10:21 AM
topanga's Avatar
Default Fitting Rear Lower Control Arm
Just been trying to remove the rear front lower control arm (baby arm). The inner bolt came out with a bit of a fight but the outer bolt (nearest the wheel) was solid, even after two days soaking in penetrating oil. The captive nut has broken lose and and come off so I am now left with the bolt turning and being seized solid to the bushing, the bushing is spinning with the bolt. I think my options are to cut the bolt head off and try using a punch to hammer the bolt through, or use a cutting wheel on my angle angle and cut the lot off. Anyone been in a similar position and any better ideas?
Old May 29, 2022 | 12:00 PM
Gophat's Avatar
Introduce some heat into the situation if you can, that's what I usually do and it works out for me.
Old May 29, 2022 | 04:27 PM
Dell Gailey's Avatar
Reweld the captive nut, penetrating fluid, out/in/out/in on bolt with breaker bar if needed.
patience.
https://m.youtube.com/watch?v=wfpcPVoKN18
https://m.youtube.com/watch?v=Flwl9ndp7ac
Old Jun 1, 2022 | 03:11 PM
topanga's Avatar
Thanks for everybody's suggestions, I took the most direct route and used an angle grinder to take off the bolt head and then used a cutting disc to cut the bolt in half, it was off in 10 minutes. Just waiting for the new bolt to arrive though, won't be here until Monday.
cooldood
Feb 8, 2022 05:27 PM
Playerpetegunn
Nov 28, 2020 03:55 AM
prodigy215
Jun 10, 2020 02:31 PM
zak
Oct 13, 2015 11:46 AM
calvindoesntknow
Aug 2, 2013 06:22 PM
