Fixing up a totaled Jag
Old 10-27-2012, 01:21 PM
Wasatch7's Avatar
Default Fixing up a totaled Jag
So we picked up a 2004 Jaguar XType 3.0 Sport with only 43K on it and were hoping to put it all back together. So far we have gotten a new hood, headlight, radiator, fan shroud, and thermostat housing, but still missing a few parts. One thing that didnt come with the radiator was the rubber support grommets that fit into the the upper and lower support bars and I have no Idea where I could get those... Any ideas??? I am also looking for a leaper because the one that was on there got stolen while sitting in the salvage yard. Any advice on this rebuild would be much appreciated.Thanks!!!!
Old 10-27-2012, 03:05 PM
Tirefriar's Avatar
The radiator retainer grommets are dealer items and are usually less than $10 each (based on experience with other hi ends). You can ask the junk yard where you got the parts.
Old 10-27-2012, 03:58 PM
MRomanik's Avatar
Part numbers TOP C2S2685, BOTTOM C2S4405
Old 10-27-2012, 10:56 PM
Wasatch7's Avatar
Thanks for the quick replies!! Just searched up the part number and found exactly what I was looking for. Next job, anyone had any experience changing headlight adjusters?? Thanks again!!
Old 10-28-2012, 07:34 AM
cujet's Avatar
Ahh, the subject of headlight adjusters.
They deteriorated on my car, to the point where they were dust! I took my headlights apart, using a heat gun and prying carefully. I then fabricated a "cheezy" adjuster from threaded rod, a bit of braze on the end, some epoxy and a spring. I installed a nut on the outside and it works, kind of.
I re-assembled my headlights with a hot glue gun. It's held up for 4 years now. I polished the lens with a small "snap on" brand 3 inch buffer and rubbing compound. They look good.
99xk8guy
06-05-2023 06:28 AM
Forcedair1
05-14-2023 03:28 PM
allenman85
05-10-2021 03:11 PM
Shawn Svacha
11-04-2019 02:47 PM
KarimPA
09-03-2015 07:32 PM
Quick Reply: Fixing up a totaled Jag
