Floppy headlights!
Old Nov 17, 2015 | 04:42 PM
hlgeorge's Avatar
Default Floppy headlights!
Today I was going to replace the front left(driver side) parking light. I opened the headlight case and reached in. To my surprise the panel that all the lamps are attached to just flops around inside the casing. Is there a fix or am I looking at a replacement headlamp fixture?
Old Nov 17, 2015 | 06:52 PM
avern1's Avatar
Most likely if you look around inside you will find the plastic adjusters are broken. Here is a link to a repair kit for both lights.
Jaguar x Type x Type Headlamp Headlight Repair Kit Adjuster 2 Sets Gears | eBay
You can go onto you tube for a video for repairing the lights. Unfortunately to overhaul the lights you need to remove the front bumper cover to remove the lights.
We can help you out with advice for that also.
Old Nov 21, 2015 | 07:30 PM
CWMcGonigal's Avatar
Upon replacing the 2825 Daytime Running Light bulbs today, I noticed the same thing. The reflective piece, that holds the bulbs in place, is loose and flopping around inside the passenger side head light.
Old Nov 22, 2015 | 03:24 PM
avern1's Avatar
I have a 2002 with the HID variant. I had to go thru the entire rebuild of the lights. At first i thought bumper cover removal and all would be a daunting task. It was relatively straight forward. The only hang up I had was trying to disconnect the plug for the fog lights.
Everything went well and the kit fit perfect. Let me know if you would like further info. Send me a PM and i will send my email address.
Old Nov 22, 2015 | 09:11 PM
hlgeorge's Avatar
Found a good deal on some new headlights, so bit the bullet!
philwarner
Oct 31, 2015 03:42 PM
philwarner
Oct 31, 2015 11:31 AM
Chuck Schexnayder
Oct 30, 2015 11:55 AM
Chris Jenkins
Oct 22, 2015 07:15 PM
DaveInVA
Oct 21, 2015 03:33 PM
