Front door wind noise
Old Oct 20, 2019 | 06:05 AM
Elsaetka's Avatar
Default Front door wind noise
Hi
I would appreciate some tips from members who have cured this problem.
My X Type estate has wind noise at speed, 55 / 60 Mph plus. You would think the window or door wasn't shut properly. Especially when someone overtakes me at speed, it's quite loud.
I fitted a couple of front Heko wind deflectors to see if it makes a difference, unfortunately apart from making the car look cooler they did nothing. I read a post saying Heko are noisy on X Types. I just took them back off however to me theirs no difference, the fault is with the car.
I spotted an old post when researching this saying move the door striker a couple of mm inward, that received some positive feedback, so will be worth a try.
If someone has cured this please let me know what I need to do. There are no visible signs of problems either with window trim or door seals.
Thanks in advance.
Old Oct 20, 2019 | 01:08 PM
astromorg's Avatar
Have you checked that the window is fully shut outside? From inside it can appear shut but outside is about an 1/8'' short and won't correct by following the usual reset procedure. Disconnect the battery briefly and start again!
xjfourty
Jun 13, 2018 11:47 AM
emaraszek
Apr 5, 2013 04:01 PM
Lulette
Jun 19, 2008 10:52 PM
cosworth
16
May 21, 2008 01:45 PM
