Front right axle replacement
Old Jul 23, 2018 | 01:05 PM
mzjasmin78's Avatar
Default Front right axle replacement
A mechanic replaced right front axle on 07 Jag X Type. All axles put in keep slipping out and car cannot go into gear. Found out that there is damage to trasnfer case and the spring was broken which is why axles disengage. Original repair guy says it has to be damaged before he replaced axle. Vehicle drove fine and axle only replaced because mechanic said it was causing the clunking noise while driving. Clunking was still present when axle put in. Could the old axle stay in place if the spring was already damaged before repair? Also mechanic took whole shaft out and I was told it is only suppose to be a half shaft replacement so the trasnfer case is not damaged. Please help! Need to recover my losses!
Old Jul 23, 2018 | 04:25 PM
Dell Gailey's Avatar
He damaged it. Just do search (advanced) here and you can read how and what he damaged (the inner clip/seal). Many, many discussions on doing it wrong and correctly.
Old Jul 23, 2018 | 04:32 PM
mzjasmin78's Avatar
Hey thanks for the quick reply. I am new to the site so I am unsure how to do an advanced search. Can you guide me on where I need to go? Much appreciated!
Old Jul 23, 2018 | 04:39 PM
Main page, search pull down menu, advanced, input what you are looking for (i.e. cv, transfer case, obd code #, a/c hot, etc) change "all forums" to X type (only).
polarisnavyxj
Nov 21, 2016 04:57 PM
polarisnavyxj
Oct 30, 2016 11:40 AM
Lawrence
XJ40 ( XJ81 )
Oct 29, 2016 05:56 PM
finance1
Oct 25, 2016 02:49 PM
bojangles
Jan 29, 2007 08:20 PM
