Front Strut Advice
Old Sep 27, 2014 | 11:23 AM
bostongrun's Avatar
Default Front Strut Advice
I need to install new front struts. I just looked at the manual and it says I need a special tool to drop the subframe, remove the axle and be wary of the rear subframe mounting nut. I have seen other write ups on this and other forums that are not as complex. It appeared you merely had to loosen the the rear subframe bolt to get clearance. Has anyone ever done this job who can tell me the easiest way to do it and what pitfalls I may encounter.
Old Sep 27, 2014 | 01:38 PM
Dr dome's Avatar
Its not as hard as it looks on paper. Just need to make sure that you can loosen the back sub frame bolt as they have been known to rust and break off.(pb blaster is your friend) When you get them loose best thing is to take them most of the way out, then loosen the main bolt holding the bottom of the strut. Then take off your brake line and sway bar link. Next what I do is use a ratchet strap and put around the lower control arms across the under part of car and ratchet tight. Then get a heavy hammer.(3 pounds or so) and tap down on the spindle keeping clear of the sensor. After a few hits it should be free. then take off your 3 bolts that hold it on and your done. Just remember when re install to be careful of the set tab on the back of the strut.make sure its centered in the back.
Good luck,
The Dr!
Any questions pm me and I will send you my cell and help you through it
Old Oct 2, 2014 | 05:07 PM
Dr dome's Avatar
so did you get a chance to get it done
bamforp
Aug 14, 2024 05:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
34by151
Sep 6, 2015 05:14 PM
