Front Wheel Bearing DIY with Photo's
Old Apr 5, 2018 | 07:33 PM
  #41
ddsand's Avatar
Thank you for the tutorial. I replaced mine the other day and could not have done it without the tutorial. I did not try the ice and heat because I have a friend that has a press, however, everything else was extremely helpful.
Old Jun 14, 2024 | 05:54 AM
  #42
antiqueman's Avatar
I had a right job getting the bottom ball joint out as the swinging arm would not drop far enough, seems it has now stuffed the swinging arm bush by using a very big bar on it, hey ho, now I find your post is that why you say some undo the strut?
Old Jun 15, 2024 | 05:15 AM
  #43
tomgee111's Avatar
Default Wheel bearing Conundrum
Getting the bearing out of the hub turned into a challenge though I had a bearing extraction tool and Pneumatic air gun, could not get it to budge from the hub. Finally took the Hub and the bearing to a shop with a bearing press that cost about $100 that I was more than happy to pay. So, have a backup plan just in case you run into the same problem.
PMKimpton
Aug 3, 2019 08:22 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
innzane
Sep 2, 2015 10:08 AM
