Fuel Pump Control Problem
Old Jan 25, 2020 | 08:35 PM
jamwilbat's Avatar
Default Fuel Pump Control Problem
G'day All.
I have been playing with the 2.1l X type for over a week now but I still can't get it to run normally.
If I connect the pump up to an external 12v supply it runs OK and draws 6amps so the pump is working.
The supply wire to the pump was open circuit so I ran a new one and now without the pump plugged in the relay operates and I get battery voltage at the pump plug when it is not in circuit.
As soon as I plug the pump in the relay drops out and of course no fuel pressure.
I have cleaned all the earths and ran a separate earth wire to the pump but to avail.
Are there any auto lecky's out there who know what the problem is?
Keep happy
JB
Old Jan 25, 2020 | 08:37 PM
jamwilbat's Avatar
Sorry I should of said with the pump not plugged in I am getting battery voltage at the plug.
Old Mar 27, 2020 | 07:20 PM
jamwilbat's Avatar
Just to update I eventually traced the problem to a high resistance in the relay base.
after a lot of fiddling I changed all the wiring over to one of the spares and now works fine.
Keep happy and healthy
Jim
WhiteXKR
May 12, 2026 01:19 PM
Hog883
Sep 25, 2016 05:26 AM
Wascator
May 10, 2013 09:49 PM
powellwm
Dec 29, 2011 02:11 PM
