Fustrating Issue PLS HELP
Old Jul 22, 2009 | 08:31 AM
teflondon's Avatar
Exclamation Fustrating Issue PLS HELP
Hey Jag Family. I have a small annoying issue with my passenger door not opening from the outside some times. Some times it open fine and others.. not so much. I've physically closed the latch on the door and opened the latch disengaged every time but as soon as i close the door the Russian roulette begins. I'm somewhat of a do-it-yourselfer to a degree. So if it's something not that hard to try, I'll appreciate it.
SOME ONE PLS HELP!!
Old Jul 22, 2009 | 10:57 AM
The Chris X's Avatar
Search the board - this is a common problem. I ended up having 3 of my latch mechanisms replaced under warranty.
Old Jul 27, 2009 | 09:27 PM
kandA's Avatar
I am glad I am not the only one. My 02 X-type just started doing this occasionally. I was wondering about taking off the door panel to see if some of the mechanisms in there need to be cleaned/lubed or something.
Old Jul 27, 2009 | 10:47 PM
Hey teflondon,
check out the x type faq quick links.....there's a FAQ for the step by step door panel removal that'll get you in to have a look. There's a problem with the linkages on the older models if I remember correctly. This was fairly well documented some time ago although I can't seem to find a FAQ for it.
Maybe someone would do a write up with pics and we will FAQ it for future reference.....its always cropping up
Old Feb 23, 2014 | 12:50 PM
wollar's Avatar
Default can anyone help
i can any one help my x type air bag light flashes 4times then goes out for a few seconds then flashes twice the out for a few seconds then stays on
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
carelm
Sep 5, 2015 01:13 AM
