Gearbox fault and engine systems fault after driving into downpour
Old May 27, 2019 | 05:06 PM
Scottishman58's Avatar
Default Gearbox fault and engine systems fault after driving into downpour
Last week I was driving home and my 2006 Jaguar X-Type Sport Wagon was driving Like a new car. Suddenly, I drove into a downpour. My gearbox fault message came on. The car went into limp mode. I managed to drive it home, parked it let it sit overnight and started it again the next morning. It started; the gearbox fault message was still on. I put it into reverse, the engine stalled out and the engine systems fault message appeared. I turned the car off, turned the key back on all the systems lit up but the engine would not turn over. Thoughts?
Old May 27, 2019 | 05:49 PM
Welcome to the forums Scottishman58,
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
Old May 27, 2019 | 06:50 PM
Dell Gailey's Avatar
ECU or TCM got wet
Check the ECU and TCM fuses to see if they blew, then proceed =
https://www.jaguarforums.com/forum/x...emedies-72301/
If you need to remove the ECU, you'll need the FIVE star security (tamper proof) torx to remove it. Internet search will get you one reasonably.
Old May 29, 2019 | 03:38 PM
Thank you, Dell
Khb1
Mar 6, 2018 03:05 AM
afonda
Jan 27, 2013 04:13 PM
guoyesheng
Jul 4, 2011 01:16 PM
