Going nuts
Old Jan 5, 2017 | 06:56 PM
Adriana Rivera Quirin's Avatar
Default Going nuts
Ok I have a 2002 xtype jaguar...sound like the fan is still on when the car is off...I don't kno what too do
Old Jan 5, 2017 | 07:44 PM
swingwing's Avatar
OK, not to worry. We'll help. First of all please give us more info on your car, such as transmission type, miles, maintenance history (i.e., don't have a clue to I know everything that's been done to it, or in between). To start off with, what's the coolant level in the expansion tank, and when's the last time coolant was serviced? If you don't know what the expansion tank is, take a look at my picture. Expansion tank is the container on driver's side of engine bay. You can see level through the tank. What do you see here?
Expansion tank is on lower right corner - opaque container with black top.
Old Jan 6, 2017 | 03:38 AM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
There is a little fan inside the car that keeps running on - by design - for some time after you turn the engine off.
This is normal.
Originally Posted by Aonsaithya
There's much going on behind the dash, but the most common thing heard is the tiny aspirator fan that samples cabin air for the aircon temp sensor. It's the small grille next to the steering wheel.
https://www.jaguarforums.com/forum/x...und-dash-4926/
https://www.jaguarforums.com/forum/x...-x-type-95159/
https://www.jaguarforums.com/forum/x...ion-off-29753/
https://www.jaguarforums.com/forum/x...nd-dash-69687/
