Ground battery cable
Old Jul 7, 2018 | 02:52 PM
new mexico's Avatar
Question Ground battery cable
2002 X type 3.0
What is the correct part number for the ground cable for this model from barratt?
Are there better cables from napa etc.???
Has anybody the info. on installing these cables ?
Walter
Old Jul 7, 2018 | 05:12 PM
avern1's Avatar
Going thru the drill down for SNG Barratt shows that only the new version of the cable is now available. The older style you have is no longer stocked. So where to go from there. It should fit your battery just fine. I don't know where the additional ground wire is meant to connect. You could snip it at the connector or bolt it under a convenient body/chassis fastener.
The local auto stores are not going to have the pesky 90 Degree bent clamp configuration used on the x-type and a straight one will not let the battery cover mount back on without cutting. To replace the cable you have to remove the battery, the battery box and then you will see the mounting point for the end of the cable beneath the battery mounting plate. I removed the plate for ease of access but it isn't necessary., when you have it off polish and clean all of the surfaces before reassembly.
1 of 19
Oct 31, 2016 08:46 AM
Doug Dooren
Jun 1, 2016 04:39 PM
WhiteXKR
Feb 2, 2016 11:15 PM
waterloo
Oct 8, 2013 12:49 AM
sh500
Sep 1, 2008 12:55 AM
