Ground near power steering location or compressor
Old Jul 16, 2025 | 07:00 PM
Ronks2's Avatar
Default Ground near power steering location or compressor
I am stuck in Limp mode and someone referenced checking the grounds and that there was on e near the power steering. I found one on the power steering reservoir that i did clean.
Is there a ground cable near the power steering pump?
Are there any grounds I could have disturbed when i replaced the AC compressor?
At one point i had a nice ground chart for the X type, but it is missing, and the others i found seem very generic and of little use.
Any help would be appreciated.
Ron
Old Jul 16, 2025 | 10:12 PM
h2o2steam's Avatar
This is the only reference to grounding points I have for production 2005 onwards.
Looks like you need to check the grounds on alternator bracket, ABS mounting bracket and RHS strut tower to see if you have inadvertently disturbed something.
Good luck
Old Jul 18, 2025 | 09:10 PM
Ronks2's Avatar
Thank you for sharing this diagram.
Ron
MrVette
E type ( XK-E )
Mar 3, 2024 10:22 AM
sigard
UK & Eire
Feb 12, 2024 08:12 AM
etaent
XJ40 ( XJ81 )
Aug 28, 2023 09:40 AM
sunchip
Jan 28, 2015 08:21 AM
