Growling noise from steering XType 51 plate
Old Oct 26, 2014 | 11:13 AM
Companyboy's Avatar
Default Growling noise from steering XType 51 plate
Started getting a growling noise from left side when steering was on full lock.
This then spread to the right side about three weeks later, and has now become more regular even when steering has only been moved slightly. Fluid is at correct height and car has no signs of leaks from steering system. Steering is also still working fine and feels light as if working normal. This is not connected to the noise that sometimes emits from steering wheel which I fix with additive. I am at a loss so any help would be welcome. Thanks in advance.
Old Oct 26, 2014 | 07:53 PM
Thermo's Avatar
Veteran: Navy
companyboy, odds are if you apply a little bit of lube to the bearing for the steering shaft where it goes through the firewall, you will find that the noise will go away. When this bearing gets dry, it will make some noise similar to what you are most likely hearing.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
mls0036
Oct 17, 2015 10:03 AM
millertic
Sep 20, 2015 10:14 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
