Harsh Suspension- Anyone Tried and like the Air ride Susp?
Old Feb 28, 2010 | 10:52 PM
jag2020's Avatar
Default Harsh Suspension- Anyone Tried and like the Air ride Susp?
I have my 2003 X-type 2.5 going in for inspection in a few days because the suspension makes harsh banging sounds when i hit even the smallest of bumps or road changes. The noise focuses on the front of the car and sometimes is harshest on the right front tire. I also wonder if it has to do with the vibration of the front tires. I got them balanced recently but the dealership didn't do a very good job, and they seem to have gotton worse. Has anyone had this problem? And has anyone ever tried the air ride suspension on an x-type? Im wondering if it would make a significant difference in ride noise and quality. Thanks for your help
Old Mar 1, 2010 | 07:39 AM
The Chris X's Avatar
A common problem. There are a number of threads on this topic. Most likely you have swaybar bushings that are toast.
Old Mar 1, 2010 | 11:27 AM
Pete04xtype's Avatar
Well when it is in for inspection they will check the front end and let you know if the bushings are bad.. With the noise you are describing I would say that it is the front bushings that are bad and causing all the issues.
As for an air ride suspension on your X.. I think its a lot of money that really doesnt need to be spent. If you want a better ride then upgrade to better struts like Bilisten or KYB for a firmer ride. You could also go onto Mina Gallery and get the full suspension kit for your X.
Old Mar 3, 2010 | 08:58 AM
shaynes's Avatar
Among other things that is something close to what mine is doing. Mine is making a thumping noise that seems to be coming from the front driver side but is on and of it reminds me or makes me think that there is a knot on the tire but it doesnt do it all the time and most of the time it does it when I am coasting but it gets pretty loud. I was thinking maybe a ball joint I am going to be working on it this even so any help on what to look for would be great. I have larned there are a lot of very knowledgeable peopl on this site and thats the reason I have been posting so many questions so anybody have any idea? Thanks again for all your help
mel
Sep 20, 2015 04:56 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1LowCat
Sep 14, 2015 07:51 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
mhamilton
US Lower Atlantic
Sep 4, 2015 05:00 PM
