Headlight adjustment
Old Jan 8, 2016 | 03:59 AM
matthew.r's Avatar
Default Headlight adjustment
Hi,
I have a 2004 3.0L V6 Estate which is LHD (I live in France), the car is on UK plates where I bought it last month. I want to register it here in France and need the equivalent of an MOT. I have read somewhere that there is a lever on the headlights which will change the dip to European settings. I would like to try this first before going to the expense of buying LHD light units which are not cheap even second hand! Could someone please provide a diagram and possibly a photograph of the lever?
I am sure I saw a thread on this forum but cannot find it now!!
I would be grateful for any information and help.
Regards
Old Jan 9, 2016 | 08:50 AM
Thermo's Avatar
Veteran: Navy
Matthew, pull out your owners manual (if you need a copy, let me know) and look on page 4-20. That will have the step by step instructions on what you need to do. In short, you need to pull off the back cover of the headlights and inside you will find a silver lever that can be flipped to change it from UK to Euro Spec.
Of note, you may find that getting your hand in there may be a bit difficult. Also, you need to be careful with the internals of the headlights as we have found that over time the plastic has become brittle and if pushed too hard, will break. So, you may find that pulling off the bumper cover may be a good step to take. It isn't hard to, but will probably add an hour or so to the job (if you need more assistance with this, let me know).
Old Jan 9, 2016 | 10:00 AM
matthew.r's Avatar
Hi Thermo,
Thanks for the reply. My local garage had a look this morning and at some time one headlight has been damaged much as you say. I am now resigned to buying new headlights and having them fitted and adjusted properly for the French Controlle Technique. Before I do that perhaps you could send me the relevant pages please by pm if necessary.
Regards
amorris6015
Jul 17, 2024 12:38 PM
Smudge78
Jan 27, 2016 06:25 AM
Narda 1
Dec 30, 2015 01:25 PM
Euclid
Dec 15, 2015 04:14 PM
GoodWins62
Nov 17, 2015 12:43 AM
