headliner
Old Jun 16, 2012 | 12:16 PM
Adam Lueb's Avatar
Smile headliner
The headliner on my 03 is working it way off the ceiling of the car. In the rear against where it meets the top of the rear window. I took it to a upholstery shop and they told me that it can't be reglued as the re-glue won't hold. I re-glued the headliner myself last year in the winter when the part the covers the moonroof came down and its been OK. The headliner is in fine shape no tears clean etc. The shop wants $250 for a new liner, that's just material and labor. I can't understand why a good headliner glue won't hold on the old headliner.
Anyone had a headliner problem and what did you do about it.
Old Jun 16, 2012 | 01:28 PM
Thermo's Avatar
Veteran: Navy
Adam, I have had the headliner come off where you are talking about. I used some newspaper to cover up the rear window (held in place by masking tape) and then I peeled the headliner back a little more to get good access. From there, I used some 3M Upholstery spray glue. Sprayed both the headliner and the base and then laid it back down. Been good for 3 years now. Just have to do the other side now.
Old Jun 16, 2012 | 04:21 PM
RapidRabbit's Avatar
I have the same problem. Mine is coming down in the back and I was just planning to try an upholstery glue. If it doesn't work it still needs to be replaced anyway. Might as well try it. Mine is pinned up right now until I can get to it.
Old Jun 17, 2012 | 08:41 AM
Adam Lueb's Avatar
Smile Headliner
I am going to try and get my son to hep me re-glue it because of my back problems I can't contort myself into the position I need to be in. Thanks for the help.
Old Jun 18, 2012 | 04:03 PM
Adam Lueb's Avatar
Smile headliner
I found some headliner glue in a spray can, supposed to be made just for this type of job. However, the seller told me not to be surprised if it does not hold, or when you lay the headliner back it is not perfectly smooth. He quoted me a price of $200 for a new headliner with a year warranty.
bdboyle
Sep 16, 2019 05:58 PM
ArtyH
Oct 2, 2015 11:39 AM
Col. Sandurz
Sep 28, 2015 07:29 PM
BlacXJRcat
Sep 25, 2015 06:43 PM
