Heat Shields
Old Oct 26, 2011 | 12:57 PM
zoolander's Avatar
Default Heat Shields
As I was locating and eradicating annoying rattles from the car that I've nicknamed the "if aint one thing it's 2" I had to remove the heat-shields from around the gas tank...now the exhaust is somewhat close to the gas tank and I'm wondering if I should be doing something offer the fuel tank better insulation from the exhaust pipe or is this something not to fret about? Thanks
Old Oct 26, 2011 | 03:50 PM
Thermo's Avatar
Veteran: Navy
zoolander, I would recommend putting some form for heat shield there. WHile not having anything there is probably fine, I would hate to see something go awry.
Old Oct 27, 2011 | 12:14 PM
sidewalkman's Avatar
Go to a hot rod supply store, there is a 3M product that is peel and stick. It effectively reflects the heat back and since it's stuck on the gas tank won't rattle, but you do need something. Even it it doesn't explode, who wants to run hot gas?
Old Oct 27, 2011 | 12:53 PM
zoolander's Avatar
I just ordered some stuff called "Cool It" by thermo tec and it should hopefully do the trick....I definitely don't want to turn into a giant fireball!
Poet
Feb 7, 2025 02:18 PM
aode06
Jul 28, 2023 02:26 PM
Delta66
Oct 4, 2015 05:40 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
