heater blowing cold
Old Oct 28, 2011 | 12:57 AM
Rockyf's Avatar
Default heater blowing cold
Last year I had my AC condenser unit replaced in my 02 X-type. Now that the weather's getting colder, I'm using the heater more.
The issue I have is it takes 10 to 15 minutes before the warm air comes out. I also noticed that sometimes it will take longer but when I get to the highway it warms up quickly. sometimes hit & miss.
Any thoughts or idea why?
Thanks.
Rocky
Old Oct 28, 2011 | 08:11 PM
MARVSGT's Avatar
Rockyf,
Last winter, I had a very, very slow coolant leak at the water pump. Once the coolant dropped to a certain level, my heater would blow cold air while idling like at a red light. As soon as I was in motion, the heater would blow hot air fine. Once the leak was fixed and my coolant level full, no more problems. So check your coolant level, could be that simple. Hope this helps.
Old Oct 29, 2011 | 02:37 PM
MeatBag's Avatar
Default Yep - Counter-intuitive-but check your coolant
When my coolant tank went leaky on me, the first symptom i noticed was no/intermittent heat. First place to check is the coolant expansion tank on the top right side of the engine bay - there's a hose comming out at the bottom, and the plastioc nipple that small hose connects to tends to crack.
Old Oct 31, 2011 | 07:37 PM
Rockyf's Avatar
Sure enough, coolant is leaking. I'll have my mechanic fix it this week. I think that should solve it...I'll let you guys know if it's other than that. Thanks.
xjrjag
Oct 12, 2015 03:16 PM
damienedwards
Oct 3, 2015 02:47 PM
Darrenmb
Sep 27, 2015 08:43 AM
42Ajd
Sep 26, 2015 07:04 PM
