Help! Another door-lock issue, but with different symptoms.
Old Oct 28, 2010 | 06:06 PM
JagLawry's Avatar
Default Help! Another door-lock issue, but with different symptoms.
Hey Folks,
I've read many threads regarding difficulties with doors not opening from the outside (in my case the driver's door), but none so far have addressed the following issue.
I have an 02 X-Type. Once the driver's door is opened from the inside, I can open & close the door all-day from the outside, but as soon as the doors are locked & unlocked, the driver's door will no longer open from the outside and has to be opened from the inside again!
I removed the door panel and moved up the threaded rod, but it didn't fix the problem. I can feel that it unlatches faster since the rod is adjusted but I still can't open the door from the outside.
Is there anyone out there that has experienced this problem?
Thanks in advance!
Old Oct 30, 2010 | 04:05 PM
JagLawry's Avatar
Is anybody familiar with the smaller of the two rods that's responsible for locking and unlocking? I'm thinking that the driver's door is not unlocking and that's why I'm not able to open it from the outside!
Any advice would be greatly appreciated!
Old Oct 30, 2010 | 09:20 PM
motorcarman's Avatar
I have an old TSB for diagnosis and one for the need for a stronger link rod.
bob gauff
File Type: pdf
File Type: pdf
Old Oct 30, 2010 | 10:21 PM
JagLawry's Avatar
bob gauff
Motorcarman,
Thanks for the TSB's, but when I click on them I get the error below. I'm guessing that it may have something to do with the fact that I'm a new member. Is there another website that I can download these from?
Thanks Again,
JagLawry, you do not have permission to access this page. This could be due to one of several reasons:
  1. [*]
Old Nov 1, 2010 | 02:51 PM
JagLawry's Avatar
I've noticed that even opening the door from the inside is troublesome. I have to pull harder on the inside handle as opposed to the other doors. I think it could be a lubing issue... I'm thinking of using some white lithium grease on the lock.
I'll let you guys know if it helps. In the meantime, if anyone could point me to where I can download the above TSB's, I'd appreciate it very much.
Old Nov 6, 2010 | 09:53 AM
jaglover922's Avatar
Originally Posted by JagLawry
Hey Folks,
Thanks in advance!
The link rod, or threaded rod that you are talking about should be replace. Jaguar has an updated link rod available. If you do it yourself, The glass has to come out and take extra care with the handle removal because that will have to come out to do this link rod. The link rod is attached to the handle by a clip. DONT BREAK the clip.
Old Nov 8, 2010 | 02:47 AM
JagLawry's Avatar
Thanks for your reply. I'm under the impression that the rod in question is connected to the outside handle only (this rod, or rather the mechanism seems to be functioning, since I can open the door once it's first opened from the inside). I think the problem might lie with the driver's door not fully unlocking! because I can feel the tension on the inside handle. I don't know for sure though, but I'll look into the new updated rod and see what i can find.
Thanks again,
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
carelm
Sep 5, 2015 01:13 AM
XFR_Gold
Sep 2, 2015 12:24 PM
