Help! Installed double din; won't start, code P1603
Old Jan 25, 2013 | 11:06 PM
ssreyer's Avatar
Unhappy Help! Installed double din; won't start, code P1603
Installed double din and now the car won't start. Check engine light is on with code P1603 twice and P1000. The 'gear fault' message is not on. Everything is connected. Car turns on but no crank. I can read the mileage and shift out of Park. Please help me.
2003 X-type 3.0 automatic. No stock navigation.
Old Jan 26, 2013 | 03:11 AM
ssreyer's Avatar
Update: Disconnected the battery completely both negative/positive for an hour and car turned on. Cleared codes with scanner, seems fine now. Most likely from a low battery (12.40v).
Old Jan 26, 2013 | 03:18 AM
steveinfrance's Avatar
Possibly, but that's not terribly low and an unusual code to throw.
Keep checking the codes until P1000 (DTC cycle incomplete) turns to P1111 (DTC OK).
Old Jan 27, 2013 | 02:56 PM
Jeeves12's Avatar
Have the battery checked for amperage. I had a battery read over 12v, but the amps were below 200. Bad battery.
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
David Thompson
Sep 3, 2015 07:48 PM
