Help with MAF sensor install please
Old Mar 6, 2024 | 02:08 PM
NYCJAG2006's Avatar
Default Help with MAF sensor install please
I’m gonna install a new MAF sensor and have a question. Should I disconnect the battery before doing the install ? I’ve read about the cpu reset by disconnecting the 2 battery terminals then touching them together for a few minutes. I’m a little afraid of doing that. Is there any other option ? Or is disconnecting the battery not really necessary ? Please let me know thx.
Old Mar 6, 2024 | 07:20 PM
Dell Gailey's Avatar
Not needed
Old Mar 6, 2024 | 09:21 PM
NYCJAG2006's Avatar
Thx Dell. Will update in a few days.
Old Mar 7, 2024 | 01:47 PM
Thermo's Avatar
Veteran: Navy
NYCJAG, I have replaced tons of MAF sensors and never disconnected the battery. So, do not worry about it. Granted, I would say to disconnect the battery to let the computer learn the new sensor. As for touching the two terminals together, BAH!!!!!! It is a way to discharge everything in the car to get it all discharged. Or, you can simply let it sit for a few minutes and the internal circuitry to drain any remaining voltage left in the capacitors. That is a lot easier on the electronics than shorting the two main wires together.
Old Mar 7, 2024 | 02:35 PM
NYCJAG2006's Avatar
Thx Thermo. So just remove the negative battery terminal and let it sit for half hour ? Or less time ? Thx again
jagstuart
Dec 22, 2023 07:35 AM
Scotlad
Jan 8, 2022 12:47 AM
JagXK82001
Jun 16, 2019 11:58 AM
JagTheRipper
Jun 19, 2017 12:43 PM
Donzi
Mar 1, 2008 06:58 PM
