help needed
Old Feb 3, 2009 | 10:14 PM
ChrisX's Avatar
Default help needed
alrite guys if you guys could help me out i have a few questions
1.How much would a new prop shaft be?
2.Is it easy to grease the prop shaft?
3.My steering wheel is makeing a werid noise when i turn even when parked it is like a sweek?
4.Where would be a good place to find a fog light becasue i am missing one
5. Is premium the only kind of gas i could use or would plus do the job
sorry that their stupid questions its just that im so new to jaguars..
Old Feb 4, 2009 | 07:07 AM
The Chris X's Avatar
1) Expensive. Why do you think you need one?
2) Yes - see the many posts on the issue
3) Check fluid levels - may need a new rack, I had a similar problem and required rack replacement
4) Any parts store or online (google it!)
5) You will get 500 different opinions on this. The door says premium. I take that to be 91 octane or higher.
6) Change your username please, this one is taken (by me).
Old Feb 4, 2009 | 07:58 AM
Brutal's Avatar
Ill take 2 reeal quick, you can grease the prop shaft, and the squeek repair(latest) is grease/lube the lower steering column where it goes through the firewall, and add power steering additive to power steering reservoir avail at dealer.
Charlene n John
Sep 28, 2015 06:01 AM
Sprayall
Sep 3, 2015 07:49 PM
XJsc-guy
Sep 2, 2015 11:43 AM
innzane
Sep 2, 2015 10:08 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
