help needed regarding timing & crank shaft sensor target disk
Old Jul 2, 2021 | 03:39 AM
helper's Avatar
Default help needed regarding timing & crank shaft sensor target disk
my 2 lit. V6 wont start after changing head gasket.
with crankshaft sensor unplugged it starts. New sensor did not solve the problem. I have checked both sensors and resistance is ok.
now its time for finding the thing that went wrong. motor is out and i cant find any.
- the time chain seems to be ok
- the crankshaft sensor target disk has two possible sets to be mounted. Has anybody something to say about it?
Old Jul 2, 2021 | 04:43 AM
helper's Avatar
Old Jul 3, 2021 | 03:08 AM
helper's Avatar
i found it myself if someone needs it. i found that the right chain was wrong mounted, the guy that change the right hand topgasket had newer out the engine. He got the chain wrong. Now when founding the solution i will come back and write more how ir goes. thanx
blackjaguarxk8
Mar 16, 2017 02:18 PM
Swampjag
Feb 27, 2017 05:32 PM
Srids
Jun 16, 2013 08:30 AM
OPENENGINE-HELP
Dec 11, 2011 03:56 AM
Idrivejags
Dec 1, 2008 07:26 PM
