Help please
Old Dec 25, 2024 | 04:09 PM
Jplatt812's Avatar
Default Help please
I replaced front passenger side knuckle, now I got codes C1145, 55, 65, 75 + gearbox failure on dash & it will not shift out of park. Any help & knowledge would be much appreciated. Thank you🙏🏽
Old Dec 25, 2024 | 05:07 PM
Jplatt812's Avatar
It's a 2007 x-type 3.0 btw & Merry Christmas 🎄🎁
Old Dec 26, 2024 | 06:40 AM
Thermo's Avatar
Veteran: Navy
I would be looking at first the fuse for the bs module to make sure that is good, then I would make sure the connector to the abs module is properly connected. If all that is good, then you have a bad abs module. Because of the work you did, it is most likely a bad fuse or connector.
Phil m
Sep 16, 2022 10:41 AM
Eric8
Sep 8, 2021 07:53 AM
Darren6493
May 11, 2018 04:41 AM
Windycityx
Jan 3, 2012 01:16 PM
hunucru
Jul 22, 2008 04:01 PM
