Help - reverse lights are not working
Old Mar 24, 2018 | 10:06 PM
Rebecca Scott Bell's Avatar
Default Help - reverse lights are not working
I have a 2003 jag X-Type and my reverse lights are not working. Fuse is fine can someone tell me where the relay is? Auto transmission
Old Mar 25, 2018 | 06:33 AM
Welcome to the forum Rebecca,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X-Type forum. Members here with the same model will be able to help.
Old Mar 25, 2018 | 09:47 AM
JagXSE's Avatar
Check transmitter in gear box.
See
http://www.carparts4less.co.uk/cp4l/...7bdaabe&000539
If rear parking sensors work, it's not likely to be this item.
Old Mar 25, 2018 | 01:00 PM
ABR's Avatar
ABR
Hi Rebecca.
Probably the switch on the gearbox, they are known for their unreliability. Very easy to change and get to, just under the battery box.
Alan in sunny Malta
Old Mar 25, 2018 | 01:17 PM
astromorg's Avatar
The relay is R17 in the glove box fuse panel. On the left hand side of the panel are three relays in a vertical arrangement. R17 is the centre one. Fuse is F79, 10A.
Note that with the auto box there is no direct switch on the box for the reverse lights. The relay is fed from the instrument panel.
Old Mar 28, 2018 | 12:04 AM
ddsand's Avatar
Hi Rebecca, mine were out the other day on one of my 20003's. Fortunately, it was just the bulbs. I wish you the best.
WhiteTardis
Feb 3, 2022 09:28 AM
NW1996
Nov 6, 2016 01:26 PM
Dela Quao
Oct 30, 2016 12:55 PM
hirev
Oct 16, 2016 08:49 PM
Nov 29, 2005 10:40 PM
