Help with Transfer Case/driveshaft replacement. All help welcome.
Old Feb 7, 2016 | 11:02 PM
Muamin's Avatar
Default Help with Transfer Case/driveshaft replacement. All help welcome.
Hi All!
I hope I am posting correctly, if I am not please forgive me as it is my first post on this site even though I have been browsing it religiously for the last few months.
So I have recently purchased an 02 Jag X Type 2.5 sport (AWD model).
I went out to see the Bathurst 12 hour (hells yeah) and on the way back I had to avoid a collision by slamming the brakes suddenly at high speed (110kmish)
The car sounded like something went bonkers mechanically and we towed it home.
After a mechanic had a look at it, what I thought turned out true and the transfer case is gone (it scrapes and rings and bogs even though at speed the car seems fine) and the drive shaft makes some unusual noises too.
I have been browsing transfer cases to replace the one in my car and have come across a few questions:
1. Will a 3.0L TC fit my 2.5 if I find one?
2. 04+ seems the go for reliabilty?
3. Anything I should be aware of when purchasing one from a wrecking yard or when installing one?
4. What about the driveshaft? fitment will be fine?
5. Anything else that I should know about the whole ordeal?
My research has led me to very inconclusive points found randomly on the net so I thank anyone who can give any advice or can answer any of my queries.
Also, the car in fact was my High school Graduation/Uni entry gift from a loving father so its one I intend to keep, so any advice to scrap the car is unwelcome (sorry )
Old Feb 8, 2016 | 07:07 AM
DPK's Avatar
DPK
All of these questions can and should be answered by a quick call to your local Dealer..they can do the cross referencing to tell you what years and with engine types are interchangeable. Good luck
Old Feb 8, 2016 | 08:06 AM
geoffbp58's Avatar
It's my understanding, and someone far more knowledgeable will jump in (Hey Thermo!), that transfer cases are all direct replacements. '02-'03 feature a viscous differential, '04 and later are open differentials, which worked with electronic traction control, if so equipped. Putting a later transfer case in an early car kind of negates the benefit of AWD, in my personal opinion. (Open differential! All wheel drive until you need it- one wheel spins, you stop...) There is a lot of info in this forum regarding setting up/ rebuilding the transfer case before you install it. Don't scrap the car!
Old Feb 9, 2016 | 03:02 AM
Muamin's Avatar
They actually offered little to no help They just redirected me to the nearest parts center to ask (they were quite busy it seems at the time so I cant blame them)
I actually found a pretty much mint transmission with the transfer case attached from the same model car as mine and same year and engine today !!
An acquaintance of my fathers turned it up (he owns a wrecking yard but these care are pretty rare in our parts so the turn up was unexpected)
Either way a new transmission and transfer case is going in, and any ECU issues will be resolved by a friend of mine who deals with car electronics and things who said it will be no problem for him, so WIN WIN
Thanks for all your help though, it is greatly appreciated.
Old Feb 9, 2016 | 07:33 AM
DPK's Avatar
DPK
Good news..Make sure before you install everything and while you can access all the fill and drain plugs..To drain and fill all the fluids and lubes...time well spent IMO.
Old Feb 10, 2016 | 05:08 AM
Muamin's Avatar
The car got off the hoist today at around 3pm...in blistering 35 degree heat ...but yeah all the oils were changed, the gearbox and transfer case will be strengthened soon with stronger gears (money well spent since I plan on keeping the car and hopefully boosting it a little bit.)
Anyway thank you for the advice....and nice XF..I always wanted one since the day they came out
Old Feb 10, 2016 | 08:36 AM
DPK's Avatar
DPK
Great!...Hope to hear soon that you have it riding high down the roads..Enjoy my friend
HawaiiRealtor
Mar 4, 2017 08:36 PM
AzRon
Feb 1, 2016 08:58 AM
darrhel
Jan 26, 2016 09:00 AM
JagGirl1954
XE ( X760 )
Jan 12, 2016 09:18 PM
Stephenk
Jan 11, 2016 02:38 AM
